Joined: August 2007 Location: QLD Age: 26 Owner Since: 2007
**SOLD** QLD: FS: White 93 GTiR in Brisbane
she has...
114000ks
fresh cold A/C, power steering, abs, power mirrors and windows.
has 181kw at the wheels
nice te37's white as you can see. she also comes with 4 spare tyres at about 70% tread.
gab coilovers with damp adjust
Auto Arming Alarm with Imobiliser
Legal Tints
Japanese Cat Back System
Front Strut Brace
njectors cleaned
replaced gearbox + transfer + diff Oils
replaced coolant
replaced all hoses on the back of the motor
body is untouched and has a few little nicks and bumps from car parks (nothing that makes you go eww)
inside is very good, no holes from boost gauges and what not, she has a boost gauge in the coin slot (just popped the coin slot out and pushed the boost gauge in, can go back to stock in 1 min.
The gear box and clutch are new
motor is in a very good state, new oil and a new rocker seal (no oil leaks) it has a 500hp intank pump and a sard fuel pressure regulator as well as a bleed valve to help get 14psi.
Dyno says everything is where it should be, not lean not to rich.
$10,000
Any questions sms or call me on 0414723572 I'm north side Brisbane.
_________________ David
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
